Ana içeriğe geç
Lenovo ThinkPad P50 Display Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad P50 Display Replacement, Battery: adım 1, 2 resimden 1. Lenovo ThinkPad P50 Display Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery latch to the left to unlock it and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Lenovo ThinkPad P50 Display Replacement, Bottom case screws: adım 2, 1 resimden 1.
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Lenovo ThinkPad P50 Display Replacement, Bottom case: adım 3, 2 resimden 1. Lenovo ThinkPad P50 Display Replacement, Bottom case: adım 3, 2 resimden 2.
    • Lift the lower case up and off of the chassis.
    FixBot'a Sor
    Yorum Ekle
  4. Lenovo ThinkPad P50 Display Replacement, Display: adım 4, 2 resimden 1. Lenovo ThinkPad P50 Display Replacement, Display: adım 4, 2 resimden 2.
    • Use an iFixit opening pick to carefully remove the plastic bezel from the front of the display.
    • There are clips beneath the trim that need to be carefully detached.
    • Avoid using metal tools, as they can damage the plastic components.
    FixBot'a Sor
    Yorum Ekle
  5. Lenovo ThinkPad P50 Display Replacement: adım 5, 1 resimden 1.
    • Remove the four 2.5 mm screws located along the corners with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Lenovo ThinkPad P50 Display Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad P50 Display Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad P50 Display Replacement: adım 6, 3 resimden 3.
    • Carefully tilt the screen forward and lay it face down on the keyboard, making sure not to strain or damage the cable still attached to it.
    • Display (sometimes called eDP cables in laptops) and camera cable connectors often have a small metal buckle running around the socket, locking them in place. The connectors are typically wide and may have tape attached to the buckle.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Hold the buckle and cable together and gently pull the connector straight out of its socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
609 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 101
Her zaman: 582
