Ana içeriğe geç
Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly
Neye ihtiyacın var
  1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: adım 1, 2 resimden 1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: adım 1, 2 resimden 2.
    • Slide the battery latch to the left to unlock it and remove the battery.
    FixBot'a Sor
  2. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case screws: adım 2, 1 resimden 1.
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    FixBot'a Sor
  3. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: adım 3, 2 resimden 1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: adım 3, 2 resimden 2.
    • Lift the lower case up and off of the chassis.
    FixBot'a Sor
  4. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: adım 4, 2 resimden 1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: adım 4, 2 resimden 2.
    • Remove the following screws with a Phillips #00 screwdriver:
    • Seven 5.7 mm screws
    • Five 4.3 mm screws
    • Three 12.6 mm screws
    FixBot'a Sor
  5. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: adım 5, 2 resimden 1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: adım 5, 2 resimden 2.
    • Turn the computer over and open the lid.
    • Insert an opening pick in the seam between the keyboard bezel and chassis.
    • Pry around the entire perimeter until the keyboard assembly fully releases.
    FixBot'a Sor
  6. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: adım 6, 3 resimden 1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: adım 6, 3 resimden 2. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: adım 6, 3 resimden 3.
    • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
    • Detach the connectors that connect to the trackpad.
    • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
    • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    FixBot'a Sor
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
609 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 344
