Ana içeriğe geç
Lenovo ThinkPad T14 Gen 3 RAM Replacement
Neye ihtiyacın var
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Back Panel: adım 1, 1 resimden 1.
      • Use a Phillips #1 screwdriver to loosen the seven captive screws securing the back panel.
      • The screws are captive and will not come out of the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 2, 3 resimden 3.
      • Insert an opening pick into the seam between the back panel and chassis.
      • Slide the opening pick around the perimeter of the device to release the clips that hold the back panel to the device.
      • Remove the back panel.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: adım 3, 2 resimden 1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: adım 3, 2 resimden 2.
      • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
      • There is a risk to your laptop if the battery is not discharged properly.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 4, 3 resimden 3.
      • Slide the battery from the battery connector and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, RAM (Random Access Memory): adım 5, 1 resimden 1.
      • Lift the plastic covering the RAM stick.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 6, 3 resimden 3.
      • This device is missing the RAM.
      • If you do have one gently pull the metal clips on each side to disengage the clips holding the card.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo ThinkPad T14 Gen 3 RAM Replacement: adım 7, 1 resimden 1.
      • Slide the old RAM from the slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Only applicable to Intel, AMD uses soldered LPDDR5 RAM.
Jacob Langseth - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 103
Son 30 gün: 415
Her zaman: 4,153
