Ana içeriğe geç
Lenovo ThinkPad T15 Gen 2 SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the lower case: adım 1, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the lower case: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
  2. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Insert an opening pick: adım 2, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Insert an opening pick: adım 2, 2 resimden 2.
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: adım 3, 3 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: adım 3, 3 resimden 2. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: adım 3, 3 resimden 3.
    • Angle the pick down at about 30˚.
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the USB clip: adım 4, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the USB clip: adım 4, 2 resimden 2.
    • Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
    • Pry the opening case up to release the clip next to the USB port.
    • It may take significant force and multiple attempts to release the clip. You will hear a popping noise when the clip releases.
  5. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 5, 2 resimden 2.
    • Insert an opening pick on the left edge above the USB port. Slide the pick all the way up to the ethernet port to release the clips.
  6. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick on the right edge near the corner.
    • Slide the pick along the right edge all the way to the HDMI port to release the rest of the clips.
  7. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad T15 Gen 2 SSD Replacement: adım 7, 3 resimden 3.
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  8. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: adım 8, 3 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: adım 8, 3 resimden 2. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: adım 8, 3 resimden 3.
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
  9. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the SSD: adım 9, 2 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the SSD: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the SSD.
  10. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: adım 10, 3 resimden 1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: adım 10, 3 resimden 2. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: adım 10, 3 resimden 3.
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
Sonuç
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad T Series answers community for help.
Spencer Day
95.987 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.652 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 33
Son 30 gün: 108
Her zaman: 1,948
