Giriş
This is a replacement guide for the CMOS battery for the Lenovo ThinkPad T430s.
The CMOS battery powers your laptop's BIOS firmware, which is what boots up your computer and configures data flow. You can tell if your CMOS battery has died if your laptop is slow, fails to boot up, if drivers disappear, and if your laptop's date and time are incorrect.
Before continuing with this guide, make sure you review the troubleshooting guide because sometimes things may become fixable without removing the CMOS battery.
Make sure to back up your data before replacing it so you don’t lose any data while you’re doing the replacement and if you do, you will have a copy of the data. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Neye ihtiyacın var
Flip your ThinkPad over so the back faces up.
With the Phillips #0 screwdriver, remove the seven 50 mm screws on the outer edge of the case.
Remove the two 70 mm screws in the upper corners of the case.
Remove the five 50 mm screws in the battery compartment.
In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
Remove the 30 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
Pull out the Wi-Fi card.
Remove the 60 mm and 30 mm screws in the RAM stick compartment.
Flip the ThinkPad right side up and open the lid.
Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
Set the keyboard aside.
Remove the two 50 mm screws from the case covering the disk drive.
Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
Lift the palm rest up from the motherboard.
Flip the motherboard over and disconnect the CMOS battery from the motherboard by pulling the cable away from the connector.
Bir başkası bu kılavuzu tamamladı.
6Kılavuz Yorumları
Why is it necessary to continue after Step 4 where the cmos battery already appears to be accessible?
yes this is correct
Holy Crap! It's right under that square door right in the middle on the back! You only have to remove two screws!
exactly! sort of an odd guide
They went over the top with the instructions. All you have to do is take out the keyboard.
From Lenovo support:
A 37-second video that shows how to acces the cmos battery. There is a lid on the back that is secured with two screw. After loosening the two screws prying up the lid gives access to the cmos battery
The T430s service manual states to change the CMOS:
1. Remove battery pack - you’ll find a screw with the k/b symbol there (remove)
2. Remove small rear panel to access and remove another screw holding back of k/b (remove)
3. Remove keyboard- which allows CMOS to be disconnected.
Voila!
chander - Yanıt
