Ana içeriğe geç
Lenovo ThinkPad T431S Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T431S Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T431S Battery Replacement: adım 2, 3 resimden 3.
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T431S Battery Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T431S Battery Replacement: adım 3, 3 resimden 3.
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 1,417
