Ana içeriğe geç
Lenovo ThinkPad T431S Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T431S Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 3.
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 13
Her zaman: 977
