Ana içeriğe geç
Lenovo ThinkPad T440p Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T440p Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Fan Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T440p Fan Replacement: adım 2, 2 resimden 2.
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Fan Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T440p Fan Replacement: adım 3, 2 resimden 2.
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Fan Replacement, Back Cover: adım 4, 2 resimden 1. Lenovo ThinkPad T440p Fan Replacement, Back Cover: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Fan Replacement: adım 5, 1 resimden 1.
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Fan Replacement: adım 6, 1 resimden 1.
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Fan Replacement, Fan: adım 7, 2 resimden 1. Lenovo ThinkPad T440p Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Using the spudger detach the cable that is connected to the computer.
  8. Lenovo ThinkPad T440p Fan Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T440p Fan Replacement: adım 8, 2 resimden 2.
    • Remove the tape that is over the cable.
  9. Lenovo ThinkPad T440p Fan Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T440p Fan Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T440p Fan Replacement: adım 9, 3 resimden 3.
    • Screws are attached to the heat sink. Do not try to remove them; just have the screws loosened.
    • Unscrew the four screws that are attached to the heat sink by using a Phillips #0 screwdriver.
    For dGPU fans, there's an additional screw near the corner where the rainbow cable connects to the fan.
    nitetsniE - Yanıt
  10. Lenovo ThinkPad T440p Fan Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T440p Fan Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T440p Fan Replacement: adım 10, 3 resimden 3.
    • Remove the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christian Abad
1.530 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G5, Peak Spring 2019 UMass Dartmouth, Team S6-G5, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G5
3 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
The guide could go one step further as this model features a replaceable CPU.
cubytus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 18
Son 30 gün: 92
Her zaman: 4,181
