Ana içeriğe geç
Lenovo ThinkPad T440p Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Keyboard Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Keyboard Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
  5. Lenovo ThinkPad T440p Keyboard Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 5, 2 resimden 2.
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad T440p Keyboard Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T440p Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the spudger to lift the keyboard.
  7. Lenovo ThinkPad T440p Keyboard Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 7, 2 resimden 2.
    • Turn the keyboard over.
  8. Lenovo ThinkPad T440p Keyboard Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T440p Keyboard Replacement: adım 8, 3 resimden 3.
    • Use the spudger to detach the plastic protection.
  9. Lenovo ThinkPad T440p Keyboard Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T440p Keyboard Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T440p Keyboard Replacement: adım 9, 3 resimden 3.
    • Use the spudger to disconnect the cables.
    CARE !!!
    My T440p type 20AW-S0Y40T does not have a detacheable plug/ socket and so the keyboard a “soldered on” device is
    NOT DETACHEABLE in this way 21/08/20
    Fritz - Yanıt
  10. Lenovo ThinkPad T440p Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the keyboard.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Christian Abad
1.530 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G5, Peak Spring 2019 UMass Dartmouth, Team S6-G5, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G5
3 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 101
Her zaman: 7,778
