Giriş
Use this guide to replace the LCD cable in your Lenovo ThinkPad T460 laptop.
Some signs your LCD cable may be faulty include a blank, black, or flickering screen, no backlight, or horizontal or vertical lines. These symptoms may also indicate that the LCD panel is faulty, rather than the cable itself.
Before attempting a display panel replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Neye ihtiyacın var
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use your hands to peel up the thin LCD bezel sheet from the rest of the display, starting in the area between the hinges.
Use your hands to continue peeling the bezel sheet away from the left side of the laptop.
Use both hands to lift the bottom corners of the display panel
Gently flip the display panel over.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks so much for this, Kristen. I managed to fix my T460 by replacing the LCD cable using this guide.
The symptoms were quite odd: the slightest movement of the laptop hinge (even a touch, sometimes) would cause the screen to go blank and the laptop to go into hibernation. I could get it back out again using the normal method (pressing the power button), but it was happening all the time. I guessed that it was the wiring of the LCD cable causing this, so I replaced it with a branded Lenovo replacement and now it works fine.
Hi Richard,
I'm so glad to hear that you completed this repair with success! I appreciate your helpful comments throughout this guide—it's great to have insight from other people who have completed this repair.
