Giriş
This guide will show you how to replace the keyboard in your Lenovo ThinkPad T470 laptop.
A properly functioning keyboard will register keystrokes on the laptop’s display. Functioning keys will pop back up to their normal position after typing and will feel securely attached to the keyboard.
A keyboard that is malfunctioning may only register some keystrokes (or no keystrokes at all) on the laptop’s display. Certain keys may get stuck when pressed down or keycaps may feel loose and wobbly when typing.
If you suspect that your keyboard issues are software-related, visit this PCMag article for more information.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Neye ihtiyacın var
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Absolut BRAVO
Mega tolle kostenlose mit "lLiebe" hergestellte Anleitungen !
Bin 1979 auf dem 6502 mit dabei.
Dieses Dokument ist eine weitere
Bestätigung, das der Griff zu LENOVO' Produkte stehts die richtige Wahl war
wen es auch wie jetzt nur die suche nach den Befestigunsschrauben der Tastatur war.
Danke für die schöne Daus komp. Anleitung
S.Kopp
aus Luzern-CH
