Ana içeriğe geç
Lenovo ThinkPad T470 RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T470 RAM Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T470 RAM Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T470 RAM Replacement, External Battery: adım 1, 3 resimden 3.
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 RAM Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T470 RAM Replacement: adım 2, 3 resimden 3.
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: adım 3, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 RAM Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T470 RAM Replacement: adım 4, 3 resimden 3.
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 RAM Replacement: adım 5, 1 resimden 1.
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 RAM Replacement, RAM: adım 6, 3 resimden 1. Lenovo ThinkPad T470 RAM Replacement, RAM: adım 6, 3 resimden 2. Lenovo ThinkPad T470 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  7. Lenovo ThinkPad T470 RAM Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 7, 2 resimden 2.
    • Use your fingers to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  8. Lenovo ThinkPad T470 RAM Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 8, 2 resimden 2.
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  9. Lenovo ThinkPad T470 RAM Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 9, 2 resimden 2.
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
  10. Lenovo ThinkPad T470 RAM Replacement: adım 10, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 10, 2 resimden 2.
    • The RAM will pop up slightly.
  11. Lenovo ThinkPad T470 RAM Replacement: adım 11, 2 resimden 1. Lenovo ThinkPad T470 RAM Replacement: adım 11, 2 resimden 2.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
92.276 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.537 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 42
Son 30 gün: 269
Her zaman: 11,417
