Ana içeriğe geç
Lenovo ThinkPad T470 SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T470 SSD Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement, External Battery: adım 1, 3 resimden 3.
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement: adım 2, 3 resimden 3.
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: adım 3, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement: adım 4, 3 resimden 3.
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Replacement: adım 5, 1 resimden 1.
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: adım 6, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: adım 6, 2 resimden 2.
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement: adım 8, 3 resimden 3.
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
  9. Lenovo ThinkPad T470 SSD Replacement, SSD: adım 9, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement, SSD: adım 9, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement, SSD: adım 9, 3 resimden 3.
    • Use your fingers to detach the plastic bracket from the SSD assembly.
  10. Lenovo ThinkPad T470 SSD Replacement: adım 10, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 10, 2 resimden 2.
    • Flip the SSD assembly over so that the green connector board is visible.
  11. Lenovo ThinkPad T470 SSD Replacement: adım 11, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 11, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the metal bracket.
  12. Lenovo ThinkPad T470 SSD Replacement: adım 12, 3 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 12, 3 resimden 2. Lenovo ThinkPad T470 SSD Replacement: adım 12, 3 resimden 3.
    • Use your hands to lift the metal bracket up and away from the SSD assembly.
    • There may be some adhesive attaching the metal bracket to the SSD.
  13. Lenovo ThinkPad T470 SSD Replacement: adım 13, 1 resimden 1.
    • Remove the single 4 mm screw using a Phillips #1 screwdriver.
  14. Lenovo ThinkPad T470 SSD Replacement: adım 14, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to pry the SSD up slightly and pull it out of the slot with your other hand.
  15. Lenovo ThinkPad T470 SSD Replacement: adım 15, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 15, 2 resimden 2.
    • Remove the two 4 mm screws from the SSD connector board using a Phillips #1 screwdriver.
  16. Lenovo ThinkPad T470 SSD Replacement: adım 16, 2 resimden 1. Lenovo ThinkPad T470 SSD Replacement: adım 16, 2 resimden 2.
    • Use your hand to remove the SSD connector board from the metal enclosure.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
100.201 İtibar
258 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.758 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 102
Son 30 gün: 397
Her zaman: 25,447
