Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will walk you through the steps for replacing the motherboard in your Lenovo ThinkPad T470s.
The motherboard works as a nervous system for the computer; it allows components, such as the Wi-Fi card and RAM, to "communicate," running the operating system and your computer.
Motherboards can be damaged by rough handling, drops, water damage, or power surges.
Some possible indications of a failing motherboard are: your external USB devices are no longer being read by the laptop correctly, if at all; the laptop is operating much slower than usual; the computer boots with the blue screen of death, and/or any burning smell coming from the laptop while operating.
Power off and unplug your device before beginning.
Neye ihtiyacın var
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
Peel back connecting supporting tape on each of the batteries.
Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
Locate the SSD slot between the large battery and fan.
Remove the screw securing the SSD using a Phillips #000 screwdriver.
Flip up the locking gate, then pull the cable directly out of its port.
Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
