Ana içeriğe geç
Lenovo ThinkPad T480 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: adım 1, 2 resimden 2.
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 3.
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: adım 4, 1 resimden 1.
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 3.
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 3.
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 3.
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
    Hello Sarah,
    Thanks for this great guide.
    I mistakenly broke this ribbon connector on my T480 and wish you will help with any info where to source a good one and how to fit it back. It has prevent my keyboard from working.
    Adeyinka Olugbade - Yanıt
  8. Lenovo ThinkPad T480 Keyboard Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 8, 2 resimden 2.
    • Remove the keyboard from the laptop.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.698 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Yanıt
Thank you so much!
Lioneed Devotchenko - Yanıt
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 155
Son 30 gün: 670
Her zaman: 18,263
