Giriş
Use this guide to replace what Lenovo calls the camera card but is really just the internal webcam or camera in your Lenovo ThinkPad T480s laptop.
The camera card (also called a laptop camera or built-in webcam) transmits real-time videos and images to your computer. Some signs of a faulty camera include error messages that the camera is not enabled or cannot be found, or the camera light is on but the camera itself is unresponsive. There are known camera issues with Windows 10 which may be resolved with this troubleshooting guide.
If your camera is physically cracked or damaged, it may require a replacement.
Before attempting to replace the camera, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Neye ihtiyacın var
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
Use the spudger to remove the internal bezel.
Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
