Ana içeriğe geç
Lenovo ThinkPad T480s Hall Sensor Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 7, 2 resimden 2.
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s Hall Sensor Replacement: adım 8, 3 resimden 3.
    • Remove the sensor from the system.
Sonuç
Sarah Westberg
29.809 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 99
Her zaman: 3,413
