Ana içeriğe geç
Lenovo ThinkPad T480s LCD Bezel Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s LCD Bezel Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Assembly: adım 4, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Assembly: adım 4, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Assembly: adım 4, 3 resimden 3.
    • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
    • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
    • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
  5. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 5, 3 resimden 3.
    • Use the spudger to disconnect the LCD cable from the motherboard.
  6. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 6, 3 resimden 3.
    • Disconnect the camera cable from the motherboard using a spudger.
  7. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 7, 2 resimden 2.
    • Remove all antenna cables from their routing.
  8. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 8, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
  9. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 9, 3 resimden 3.
    • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
  10. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Bezel: adım 10, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Bezel: adım 10, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement, LCD Bezel: adım 10, 3 resimden 3.
    • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
    • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
  11. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T480s LCD Bezel Replacement: adım 11, 3 resimden 3.
    • Use the spudger to remove the internal bezel.
    • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
    • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
    • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
Sonuç
Sarah Westberg
29.704 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 1,606
