Ana içeriğe geç
Lenovo ThinkPad T480s Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Motherboard Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Motherboard Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Motherboard Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Motherboard Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  7. Lenovo ThinkPad T480s Motherboard Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 7, 2 resimden 2.
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  8. Lenovo ThinkPad T480s Motherboard Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 8, 3 resimden 3.
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  9. Lenovo ThinkPad T480s Motherboard Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 9, 2 resimden 2.
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  10. Lenovo ThinkPad T480s Motherboard Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 10, 3 resimden 3.
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  11. Lenovo ThinkPad T480s Motherboard Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 11, 3 resimden 3.
    • Use the spudger to disconnect the keyboard cable from the system.
  12. Lenovo ThinkPad T480s Motherboard Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 12, 2 resimden 2.
    • Lift the keyboard off of the palm rest.
  13. Lenovo ThinkPad T480s Motherboard Replacement, SSD: adım 13, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, SSD: adım 13, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  14. Lenovo ThinkPad T480s Motherboard Replacement: adım 14, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 14, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 14, 3 resimden 3.
    • Pull the SSD out of the socket.
  15. Lenovo ThinkPad T480s Motherboard Replacement, RAM: adım 15, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, RAM: adım 15, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement, RAM: adım 15, 3 resimden 3.
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
  16. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: adım 16, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: adım 16, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: adım 16, 3 resimden 3.
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  17. Lenovo ThinkPad T480s Motherboard Replacement: adım 17, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 17, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  18. Lenovo ThinkPad T480s Motherboard Replacement: adım 18, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 18, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 18, 3 resimden 3.
    • Slide the Wi-Fi card out from the slot.
  19. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: adım 19, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: adım 19, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: adım 19, 3 resimden 3.
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  20. Lenovo ThinkPad T480s Motherboard Replacement: adım 20, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 20, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  21. Lenovo ThinkPad T480s Motherboard Replacement: adım 21, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 21, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 21, 3 resimden 3.
    • Slide the WWAN card out from the slot.
  22. Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: adım 22, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: adım 22, 2 resimden 2.
    • Use the spudger to disconnect the fan cable from the motherboard.
  23. Lenovo ThinkPad T480s Motherboard Replacement: adım 23, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 23, 2 resimden 2.
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  24. Lenovo ThinkPad T480s Motherboard Replacement: adım 24, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 24, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 24, 3 resimden 3.
    • Lift the thermal fan assembly from the system and remove it.
  25. Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: adım 25, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: adım 25, 2 resimden 2.
    • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
    • Remove the SIM tray.
  26. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: adım 26, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: adım 26, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: adım 26, 3 resimden 3.
    • Use the spudger to disconnect the LCD cable from the motherboard.
  27. Lenovo ThinkPad T480s Motherboard Replacement: adım 27, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 27, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 27, 3 resimden 3.
    • Use the spudger to disconnect the camera cable from the motherboard.
  28. Lenovo ThinkPad T480s Motherboard Replacement: adım 28, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 28, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 28, 3 resimden 3.
    • Remove all antenna cables from their routing.
  29. Lenovo ThinkPad T480s Motherboard Replacement: adım 29, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 29, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 29, 3 resimden 3.
    • Use the spudger to disconnect the SD card reader/audio card cable from the board.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  30. Lenovo ThinkPad T480s Motherboard Replacement: adım 30, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 30, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 30, 3 resimden 3.
    • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
  31. Lenovo ThinkPad T480s Motherboard Replacement: adım 31, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 31, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 31, 3 resimden 3.
    • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
  32. Lenovo ThinkPad T480s Motherboard Replacement: adım 32, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 32, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 32, 3 resimden 3.
    • Disconnect the USB Card cable from the motherboard using the spudger.
  33. Lenovo ThinkPad T480s Motherboard Replacement: adım 33, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 33, 2 resimden 2.
    • Use the spudger to disconnect the power button cable from the motherboard.
  34. Lenovo ThinkPad T480s Motherboard Replacement: adım 34, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 34, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
  35. Lenovo ThinkPad T480s Motherboard Replacement: adım 35, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 35, 2 resimden 2.
    • Lift the USB-C bracket from the system.
  36. Lenovo ThinkPad T480s Motherboard Replacement: adım 36, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 36, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
  37. Lenovo ThinkPad T480s Motherboard Replacement: adım 37, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 37, 2 resimden 2.
    • Lift the trap door out.
  38. Lenovo ThinkPad T480s Motherboard Replacement: adım 38, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 38, 2 resimden 2.
    • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
  39. Lenovo ThinkPad T480s Motherboard Replacement: adım 39, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 39, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 39, 3 resimden 3.
    • Remove the HDMI bracket from the motherboard using your fingers.
  40. Lenovo ThinkPad T480s Motherboard Replacement: adım 40, 3 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 40, 3 resimden 2. Lenovo ThinkPad T480s Motherboard Replacement: adım 40, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
  41. Lenovo ThinkPad T480s Motherboard Replacement: adım 41, 2 resimden 1. Lenovo ThinkPad T480s Motherboard Replacement: adım 41, 2 resimden 2.
    • Lift the motherboard from the chassis to remove it from the device.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.686 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.643 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 41
Son 30 gün: 159
Her zaman: 5,047
