Ana içeriğe geç
Lenovo ThinkPad T480s Power Button Board Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Power Button Board Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Power Button Board Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Power Button Board Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Power Button Board Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: adım 6, 3 resimden 3.
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  7. Lenovo ThinkPad T480s Power Button Board Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 7, 2 resimden 2.
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  8. Lenovo ThinkPad T480s Power Button Board Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 8, 3 resimden 3.
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  9. Lenovo ThinkPad T480s Power Button Board Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 9, 2 resimden 2.
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  10. Lenovo ThinkPad T480s Power Button Board Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 10, 3 resimden 3.
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  11. Lenovo ThinkPad T480s Power Button Board Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 11, 3 resimden 3.
    • Use the spudger to disconnect the keyboard cable from the system.
  12. Lenovo ThinkPad T480s Power Button Board Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 12, 2 resimden 2.
    • Lift the keyboard off of the palm rest.
  13. Lenovo ThinkPad T480s Power Button Board Replacement, SSD: adım 13, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, SSD: adım 13, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  14. Lenovo ThinkPad T480s Power Button Board Replacement: adım 14, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 14, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 14, 3 resimden 3.
    • Pull the SSD out of the socket.
  15. Lenovo ThinkPad T480s Power Button Board Replacement, RAM: adım 15, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, RAM: adım 15, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement, RAM: adım 15, 3 resimden 3.
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
  16. Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: adım 16, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: adım 16, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: adım 16, 3 resimden 3.
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  17. Lenovo ThinkPad T480s Power Button Board Replacement: adım 17, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 17, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  18. Lenovo ThinkPad T480s Power Button Board Replacement: adım 18, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 18, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 18, 3 resimden 3.
    • Slide the Wi-Fi card out from the slot.
  19. Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: adım 19, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: adım 19, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: adım 19, 3 resimden 3.
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  20. Lenovo ThinkPad T480s Power Button Board Replacement: adım 20, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 20, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  21. Lenovo ThinkPad T480s Power Button Board Replacement: adım 21, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 21, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 21, 3 resimden 3.
    • Slide the WWAN card out from the slot.
  22. Lenovo ThinkPad T480s Power Button Board Replacement, Fan Assembly: adım 22, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Fan Assembly: adım 22, 2 resimden 2.
    • Use the spudger to disconnect the fan cable from the motherboard.
  23. Lenovo ThinkPad T480s Power Button Board Replacement: adım 23, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 23, 2 resimden 2.
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  24. Lenovo ThinkPad T480s Power Button Board Replacement: adım 24, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 24, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 24, 3 resimden 3.
    • Lift the thermal fan assembly from the system and remove it.
  25. Lenovo ThinkPad T480s Power Button Board Replacement, SIM Card Tray: adım 25, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, SIM Card Tray: adım 25, 2 resimden 2.
    • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
    • Remove the SIM tray.
  26. Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: adım 26, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: adım 26, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: adım 26, 3 resimden 3.
    • Use the spudger to disconnect the LCD cable from the motherboard.
  27. Lenovo ThinkPad T480s Power Button Board Replacement: adım 27, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 27, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 27, 3 resimden 3.
    • Use the spudger to disconnect the camera cable from the motherboard.
  28. Lenovo ThinkPad T480s Power Button Board Replacement: adım 28, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 28, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 28, 3 resimden 3.
    • Remove all antenna cables from their routing.
  29. Lenovo ThinkPad T480s Power Button Board Replacement: adım 29, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 29, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 29, 3 resimden 3.
    • Use the spudger to disconnect the SD card reader/audio card cable from the board.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  30. Lenovo ThinkPad T480s Power Button Board Replacement: adım 30, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 30, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 30, 3 resimden 3.
    • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
  31. Lenovo ThinkPad T480s Power Button Board Replacement: adım 31, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 31, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 31, 3 resimden 3.
    • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
  32. Lenovo ThinkPad T480s Power Button Board Replacement: adım 32, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 32, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 32, 3 resimden 3.
    • Disconnect the USB Card cable from the motherboard using the spudger.
  33. Lenovo ThinkPad T480s Power Button Board Replacement: adım 33, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 33, 2 resimden 2.
    • Use the spudger to disconnect the power button cable from the motherboard.
  34. Lenovo ThinkPad T480s Power Button Board Replacement: adım 34, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 34, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
  35. Lenovo ThinkPad T480s Power Button Board Replacement: adım 35, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 35, 2 resimden 2.
    • Lift the USB-C bracket from the system.
  36. Lenovo ThinkPad T480s Power Button Board Replacement: adım 36, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 36, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
  37. Lenovo ThinkPad T480s Power Button Board Replacement: adım 37, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 37, 2 resimden 2.
    • Lift the trap door out.
  38. Lenovo ThinkPad T480s Power Button Board Replacement: adım 38, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 38, 2 resimden 2.
    • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
  39. Lenovo ThinkPad T480s Power Button Board Replacement: adım 39, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 39, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 39, 3 resimden 3.
    • Remove the HDMI bracket from the motherboard using your fingers.
  40. Lenovo ThinkPad T480s Power Button Board Replacement: adım 40, 3 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 40, 3 resimden 2. Lenovo ThinkPad T480s Power Button Board Replacement: adım 40, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
  41. Lenovo ThinkPad T480s Power Button Board Replacement: adım 41, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 41, 2 resimden 2.
    • Lift the motherboard from the chassis to remove it from the device.
  42. Lenovo ThinkPad T480s Power Button Board Replacement, Power Button Board: adım 42, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement, Power Button Board: adım 42, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove a 3 mm screw from the board.
  43. Lenovo ThinkPad T480s Power Button Board Replacement: adım 43, 2 resimden 1. Lenovo ThinkPad T480s Power Button Board Replacement: adım 43, 2 resimden 2.
    • Remove the power button board from the system with your fingers.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
29.785 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 1,606
