Ana içeriğe geç
Lenovo ThinkPad T480s RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s RAM Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s RAM Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s RAM Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s RAM Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s RAM Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s RAM Replacement, RAM: adım 4, 3 resimden 1. Lenovo ThinkPad T480s RAM Replacement, RAM: adım 4, 3 resimden 2. Lenovo ThinkPad T480s RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Westberg
29.713 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
1Rehber Yorum
My only comment is that the photos don't show that the battery being removed. For the relatively simple task of replacing RAM on the T480s (compared to the other repairs listed here on iFixit), you are probably fine leaving the internal battery plugged in if you already turned it off via the UFEI/BIOS settings before starting this. However, I still do like to unplug the internal battery to be extra cautious.
Tai Lam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 36
Son 30 gün: 151
Her zaman: 5,496
