Ana içeriğe geç
Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: adım 6, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: adım 6, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: adım 6, 3 resimden 3.
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 9, 3 resimden 3.
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 10, 3 resimden 3.
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
  11. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: adım 11, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: adım 11, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: adım 11, 3 resimden 3.
    • Use a spudger to lift up the retaining flap on the SD card reader/audio card connector.
  12. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 12, 2 resimden 2.
    • Use the spudger to remove the cable from the connector.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  13. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 13, 2 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 13, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove two 3.1 mm screws from the card.
  14. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 14, 3 resimden 1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 14, 3 resimden 2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: adım 14, 3 resimden 3.
    • Lift the SD card reader/audio card from the system by sliding it out from the socket.
    • You will need to slide the audio card ribbon cable under the coin cell battery cable to remove the SD card reader from the system.
Sonuç
Sarah Westberg
29.698 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
1Rehber Yorum
It is not necessary to do steps 8 & 9.
K CHOI - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 54
Her zaman: 2,064
