Ana içeriğe geç
Lenovo ThinkPad T480s Speaker Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 3.
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 3.
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 3.
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Sonuç
Sarah Westberg
23.372 İtibar
70 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 57
Her zaman: 1,363
