Ana içeriğe geç
Lenovo ThinkPad T480s Speaker Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 5, 3 resimden 3.
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement, Speaker: adım 6, 3 resimden 3.
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 9, 3 resimden 3.
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T480s Speaker Replacement: adım 10, 3 resimden 3.
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Sonuç
Sarah Westberg
29.698 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 1,924
