Ana içeriğe geç
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
    Somehow I find the screws for the T480s bottom cover to be slightly more prone to stripping, compared to the ThinkPad T480 and X1 Carbon Gen 6. However, the #1 Phillips screws on the T480s have drives that are cut in a way that also let you use a #3 flathead.
    Tai Lam - Yanıt
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 3 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 3 resimden 2. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 3 resimden 3.
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: adım 6, 3 resimden 3.
    • Slide the Wi-Fi card out from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Westberg
29.785 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
1Rehber Yorum
Hi, thanks a lot the helpful guide. I have just replaced the WiFi card in my Lenovo T480s with a Intel AX210NGW. My laptop won't boot up. Even when I plug the power adapter into the laptop, the status indicator does not light up. I have removed the WiFi card and tried to power it on without it but no luck. I put back the one that was in before still no luck. I'm stuck, what can I do? Did some power component get disturbed or something? I'd appreciate any help. Thank you.
Michael Kasede - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 33
Son 30 gün: 143
Her zaman: 3,410
