Ana içeriğe geç
Lenovo ThinkPad T490 SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T490 SSD Replacement, Base Plate: adım 1, 1 resimden 1.
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 SSD Replacement: adım 2, 1 resimden 1.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 SSD Replacement: adım 3, 1 resimden 1.
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 SSD Replacement, SSD: adım 4, 2 resimden 1. Lenovo ThinkPad T490 SSD Replacement, SSD: adım 4, 2 resimden 2.
    • Grab the battery pull-tab at the top of the connector plugin.
    • Pull the connector straight out in the direction toward the cable.
  5. Lenovo ThinkPad T490 SSD Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
  6. Lenovo ThinkPad T490 SSD Replacement: adım 6, 1 resimden 1.
    • Disconnect the SSD from its socket.
    • If it requires excess force to remove, wiggle side to side while pulling.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Strongly recommend reading Lenovo's own "T490 and P43s Hardware Maintenance Manual", particularly section "1020 Base cover assembly" which gives a recommended order for prying open the clips. It's pretty easy to apply too much pressure in the wrong place and snap a clip, especially now the plastics in these laptops are getting older.
(It's also possible to remove power by changing a setting in the BIOS instead of unplugging the battery, Lenovo's guide also explains how to do this.)
projectgus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 45
Son 30 gün: 179
Her zaman: 1,864
