Ana içeriğe geç
Lenovo ThinkPad T490s Back Cover Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T490s Back Cover Replacement, Loosen the back screws: adım 1, 2 resimden 1. Lenovo ThinkPad T490s Back Cover Replacement, Loosen the back screws: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Back Cover Replacement, Release the clips: adım 2, 2 resimden 1. Lenovo ThinkPad T490s Back Cover Replacement, Release the clips: adım 2, 2 resimden 2.
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Back Cover Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T490s Back Cover Replacement: adım 3, 2 resimden 2.
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 1. Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 2. Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
82.264 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.490 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 27
Son 30 gün: 101
Her zaman: 2,070
