Ana içeriğe geç
Lenovo ThinkPad T495s Screen Replacement
Ijhanne Holder
Ijhanne Holder ve 9 diğer katkıda bulunanlar
En son June 19, 2024 tarihinde güncellendi
5 - 10 dakika
Kolay
This guide will show you how to safely remove the screen from the Lenovo ThinkPad T495s. Before embarking on this process, refer to the link below for troubleshooting monitor issues to avoid unnecessary changes. A screen may need to be removed due to a cracked screen, broken LCD, dysfunctional touch screen, or to access the hardware behind the monitor. To replace a screen, reverse the steps followed in the guide. Use caution when prying off the connections with an iFixit opening tool and tweezer to ensure no further damage.
  1. Lenovo ThinkPad T495s Screen Replacement, Screen: adım 1, 3 resimden 1. Lenovo ThinkPad T495s Screen Replacement, Screen: adım 1, 3 resimden 2. Lenovo ThinkPad T495s Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Do not start this process until the laptop is unplugged and completely powered off.
    • Use the iFixit Opening Tool to pry open the screen.
  2. Lenovo ThinkPad T495s Screen Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T495s Screen Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    • Use the angled tweezers to lift the adhesive plastic above the connection.
  3. Lenovo ThinkPad T495s Screen Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T495s Screen Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T495s Screen Replacement: adım 3, 3 resimden 3.
    • To separate the display cable connector, gently wedge your opening tool under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    • Pull in the direction of the cable to disconnect it.
Sonuç
Ijhanne Holder
431 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Petersen Spring 2022 UMass Dartmouth, Team 1-7, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 49
Her zaman: 898
