Ana içeriğe geç
Lenovo ThinkPad T500 Speaker Replacement
nicO
nicO ve 4 diğer katkıda bulunanlar
En son April 24, 2023 tarihinde güncellendi
Tahmin yok
Orta
Eksik önkoşulları
Dilim ve Zar
Daha iyi giriş
Neye ihtiyacın var
Aletler
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: adım 2, 1 resimden 1.
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: adım 3, 1 resimden 1.
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: adım 4, 1 resimden 1.
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad T500 Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad T500 Speaker Replacement: adım 9, 2 resimden 2.
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: adım 10, 2 resimden 1. Lenovo ThinkPad T500 Speaker Replacement: adım 10, 2 resimden 2.
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T500 Speaker Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T500 Speaker Replacement: adım 11, 3 resimden 3.
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the speakers.
Sonuç
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
702 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 1,289
