Ana içeriğe geç
Lenovo ThinkPad T540P RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T540P RAM Replacement, Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T540P RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Before proceeding, power down the laptop and unplug the device from the power supply / charger.
    • Flip the laptop over so the bottom is showing.
    • Orient the laptop so that the the battery bump is facing away from you.
  2. Lenovo ThinkPad T540P RAM Replacement: adım 2, 1 resimden 1.
    • On the back of the laptop are two sliding locks for the battery. These are located just beneath the battery and are marked with a little lock icon on either end.
    • Using both hands, pull these sliding locks away from each other.
    • They will stay in place once they have been fully engaged.
  3. Lenovo ThinkPad T540P RAM Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T540P RAM Replacement: adım 3, 2 resimden 2.
    • Push the battery in the direction away from where the sliding tabs are.
    • If the battery does not slide out, make sure the sliding locks are fully engaged.
    • To install a new battery, slide the battery back in with the sticker side of the battery facing down, and in the same orientation that it came out in.
  4. Lenovo ThinkPad T540P RAM Replacement, RAM: adım 4, 2 resimden 1. Lenovo ThinkPad T540P RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Loosen the two M2 x 5 mm captive screws on the large back panel with a Phillips #1 screwdriver.
  5. Lenovo ThinkPad T540P RAM Replacement: adım 5, 1 resimden 1.
    • Locate the two RAM sticks and the latches holding them in place.
  6. Lenovo ThinkPad T540P RAM Replacement: adım 6, 1 resimden 1.
    • There are two populated RAM slots on this laptop, so you will have to do steps 6 and 7 twice.
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  7. Lenovo ThinkPad T540P RAM Replacement: adım 7, 1 resimden 1.
    • Pull the RAM module directly out of its socket from the same angle.
    • To reinstall a RAM module, line up the RAM stick’s groove with the notch in the slot, and insert the stick at a 45° angle. Then push down until clamps click into place.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
AndrewH
250 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 45
Her zaman: 269
