Ana içeriğe geç
Lenovo ThinkPad T580 CMOS Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 3.
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 2, 3 resimden 3.
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 3, 3 resimden 3.
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: adım 4, 2 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 5, 3 resimden 3.
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 6, 3 resimden 3.
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 CMOS Battery Replacement, Internal Battery: adım 7, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 8, 3 resimden 3.
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: adım 9, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: adım 9, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull out the CMOS battery cable connector with a pair of blunt nose tweezers.
  10. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T580 CMOS Battery Replacement: adım 10, 3 resimden 3.
    • Using a spudger, pry the CMOS battery off of the motherboard.
    • A light adhesive holds the CMOS battery down to the motherboard. Be careful not to puncture the battery while prying it off.
    • Remove the CMOS battery.
Sonuç
Austin Blakely
21.298 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.537 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 80
Her zaman: 996
