Ana içeriğe geç
Lenovo ThinkPad T580 Fingerprint Sensor Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 3.
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 3.
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 3.
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Bottom Case: adım 4, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Bottom Case: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 3.
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 3.
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Internal Battery: adım 7, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 3.
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 3.
    • Using a spudger, flip up the black tab of the fingerprint sensor's ZIF connector on the motherboard.
  10. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull out the fingerprint sensor ribbon cable from the ZIF connector using a pair of blunt nose tweezers.
  11. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 11, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw from the fingerprint sensor bracket.
  12. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 3.
    • Lift the bracket off of the fingerprint sensor board with a set of blunt nose tweezers.
  13. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 13, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 13, 2 resimden 2.
    • Lift the fingerprint sensor out from the device with a pair of blunt nose tweezers.
Sonuç
Austin Blakely
21.355 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.706 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,190
