Ana içeriğe geç
Lenovo ThinkPad T580 Fingerprint Sensor Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, External Battery: adım 1, 3 resimden 3.
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 2, 3 resimden 3.
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 3, 3 resimden 3.
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Bottom Case: adım 4, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Bottom Case: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 5, 3 resimden 3.
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 6, 3 resimden 3.
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Internal Battery: adım 7, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 8, 3 resimden 3.
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement, Fingerprint Sensor: adım 9, 3 resimden 3.
    • Using a spudger, flip up the black tab of the fingerprint sensor's ZIF connector on the motherboard.
  10. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull out the fingerprint sensor ribbon cable from the ZIF connector using a pair of blunt nose tweezers.
  11. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 11, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw from the fingerprint sensor bracket.
  12. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 2. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 12, 3 resimden 3.
    • Lift the bracket off of the fingerprint sensor board with a set of blunt nose tweezers.
  13. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 13, 2 resimden 1. Lenovo ThinkPad T580 Fingerprint Sensor Replacement: adım 13, 2 resimden 2.
    • Lift the fingerprint sensor out from the device with a pair of blunt nose tweezers.
Sonuç
Austin Blakely
21.280 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.465 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,168
