Giriş
Welcome to the internal battery replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the internal battery.
The most common reasons why this component would need to be replaced is because:
- The internal battery is bad
- The battery no longer recharges as effectively.
If you are not experiencing these problems with this component consider examining the troubleshooting page for this device.
There are no specialized skills required for replacing the internal battery.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
2 farklı kişi bu kılavuzu tamamladı.
