Ana içeriğe geç
Lenovo ThinkPad T580 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T580 Keyboard Replacement, Unfasten the keyboard: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
  2. Lenovo ThinkPad T580 Keyboard Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 Keyboard Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 Keyboard Replacement: adım 2, 3 resimden 3.
    • Use a Jimmy to pry under the top left corner of the keyboard.
    • You may head a "click" or "pop" as the clips of the keyboard disengage.
    The keyboard should be removed by sliding it towards the screen, without the need of a "Jimmy". This releases the "hooks" shown on step 4, picture 2 and then it can be lifted safely.
    Peter Georgiev - Yanıt
  3. Lenovo ThinkPad T580 Keyboard Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 Keyboard Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 Keyboard Replacement: adım 3, 3 resimden 3.
    • Continue prying along the top edge of the keyboard, releasing the clips as you go.
    • Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
  4. Lenovo ThinkPad T580 Keyboard Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T580 Keyboard Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T580 Keyboard Replacement: adım 4, 3 resimden 3.
    • Pull the keyboard away from you, releasing the tabs along the bottom edge.
    • Be sure not to pull on the keyboard too excessively, as it is still connected to the motherboard via two ribbon cables.
    • Flip the keyboard over to rest face down over the trackpad.
  5. Lenovo ThinkPad T580 Keyboard Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 Keyboard Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 Keyboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
  6. Lenovo ThinkPad T580 Keyboard Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 Keyboard Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 Keyboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of blunt nose tweezers to pull the two keyboard ribbon cables out from the ZIF connectors.
  7. Lenovo ThinkPad T580 Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the keyboard.
    Is it just me, or in reality, do you need to push it upward, just like with the T460/T470/T470/T490 because from what I have seen, you just need to do the same thing as the W10DG model.
    Ellyot Laflamme - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Blakely
21.348 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
5Kılavuz Yorumları
Aren't there screws on the bottom of the laptop that ought to be unscrewed as well? That's what the T580 service guide says, I think.
Daniel Glus - Yanıt
This guide is wrong. You need to remove three screws on the bottom. Then slide the keyboard forward (towards the screen) and lift it up at the front to remove it.
Mart Conflin -
This guide is indeed incorrect. After just pulling the screws out of the back of the keyboard thinking they were "clips" as stated in the article, I can confirm that you DO need to unscrew the three center screws on the back of the laptop prior to removing the keyboard.
Dave - Yanıt
Hi Dave.
You and the other commenters are 100% right! I have updated the guide accordingly.
Alex Diaz-Kokaisl -
Is it possible to replace the non-backlit keyboard into backlit one?
Ahmad Naufal Firdaus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 36
Son 30 gün: 184
Her zaman: 5,871
