Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Back cover removal: adım 1, 2 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Back cover removal: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Insert an opening pick: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Insert an opening pick: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the back cover: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the back cover: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the back cover: adım 3, 3 resimden 3.
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Battery disconnect: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Battery disconnect: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Battery disconnect: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
  5. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Disconnect the battery: adım 5, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Disconnect the battery: adım 5, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Disconnect the battery: adım 5, 3 resimden 3.
    • Use the flat end of a spudger to pry up on and disconnect the battery cable.
  6. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, SSD removal: adım 6, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, SSD removal: adım 6, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, SSD removal: adım 6, 3 resimden 3.
    • Use tweezers or your fingers to peel back the plastic shield covering the SSD.
  7. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement: adım 7, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 2.9 mm screw securing the SSD to the motherboard.
  8. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the SSD: adım 8, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the SSD: adım 8, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen SSD Replacement, Remove the SSD: adım 8, 3 resimden 3.
    • Grip the edges of the SSD near the screw indent.
    • Lift the SSD up to separate it from the thermal pad.
    • Do not lift more than 5 mm or the SSD and socket may be damaged.
    • If the thermal pad is clean and intact, carefully peel it off and transfer it to the replacement SSD.
    • Gently pull to remove the SSD.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
Chayton Ritter
22.528 İtibar
105 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.426 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 62
Son 30 gün: 348
Her zaman: 16,402
