Ana içeriğe geç
Lenovo ThinkPad X1 Extreme SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement: adım 3, 2 resimden 2.
    • Using the opening tool, pop out the SSD card and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 2,328
