Ana içeriğe geç
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: adım 1, 2 resimden 1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: adım 1, 2 resimden 2.
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: adım 3, 3 resimden 3.
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
Sonuç
Beckham Richmond
466 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G3
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,830
