Ana içeriğe geç
Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement
Taylor Morgan
Taylor Morgan ve 3 diğer katkıda bulunanlar
En son October 19, 2023 tarihinde güncellendi
10 dakika
Orta
Daha iyi giriş
If you are noticing difficulties with your computer starting up, or if presets, like the date and time, are continuously resetting, it might be time to replace the coin cell battery. For more possible troubleshooting click here.
Neye ihtiyacın var
Aletler
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Coin Cell Battery: adım 3, 2 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Coin Cell Battery: adım 3, 2 resimden 2.
    • Use a spudger to pry the coin cell battery until it releases from the chassis.
    • There is an adhesive holding the battery in place; patiently pry around the coin cell until it releases from the housing, and don't use excessive force.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to "walk" out the coin cell's plug from its motherboard port, gently levering from each side until it releases.
    • Lift the coin cell battery out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 521
