Ana içeriğe geç
Lenovo Thinkpad T450 RAM Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T450 RAM Replacement, External Battery: adım 1, 3 resimden 1. Lenovo Thinkpad T450 RAM Replacement, External Battery: adım 1, 3 resimden 2. Lenovo Thinkpad T450 RAM Replacement, External Battery: adım 1, 3 resimden 3.
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 RAM Replacement, Back Cover: adım 2, 1 resimden 1.
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 RAM Replacement: adım 3, 3 resimden 1. Lenovo Thinkpad T450 RAM Replacement: adım 3, 3 resimden 2. Lenovo Thinkpad T450 RAM Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 RAM Replacement, RAM: adım 4, 2 resimden 1. Lenovo Thinkpad T450 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
  5. Lenovo Thinkpad T450 RAM Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad T450 RAM Replacement: adım 5, 2 resimden 2.
    • Using your fingers, push the two clips securing the RAM away from each other to release the RAM.
    • The RAM stick should pop up at a 30 degree angle.
    • Remove the RAM stick from the device.
    • Repeat this step for any additional RAM sticks.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin Ogihara
29.081 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
753 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 78
Her zaman: 3,048
