Ana içeriğe geç
Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement, External Battery: adım 1, 3 resimden 1. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement, External Battery: adım 1, 3 resimden 2. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement, External Battery: adım 1, 3 resimden 3.
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement, Back Cover: adım 2, 1 resimden 1.
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 3, 3 resimden 1. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 3, 3 resimden 2. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement, Wi-Fi Card (WLAN): adım 4, 1 resimden 1.
    • Lift and remove the black piece of plastic to expose the Wi-Fi card.
  5. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 5, 1 resimden 1.
    • Using the plastic opening tool, disconnect the two cables from the Wi-Fi card.
  6. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 6, 1 resimden 1.
    • Using the JIS #00 screwdriver, remove the single 2.8 mm screw.
    • After removing the screw, the Wi-Fi card should pop up on its own.
  7. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad T450 Wi-Fi Card (WLAN) Replacement: adım 7, 2 resimden 2.
    • Lift the Wi-Fi card out of the slot and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin Ogihara
29.075 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
753 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 70
Her zaman: 2,133
