Ana içeriğe geç
Lenovo V14-IIL Battery Replacement
Neye ihtiyacın var
  1. Lenovo V14-IIL Battery Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo V14-IIL Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Battery Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Battery Replacement: adım 3, 1 resimden 1.
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Battery Replacement, Battery: adım 4, 2 resimden 1. Lenovo V14-IIL Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the three 5mm screws holding the battery.
  5. Lenovo V14-IIL Battery Replacement: adım 5, 1 resimden 1.
    • Detach the battery's cable connector from the laptop.
    • Lift out the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
K.Radford
324 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 236
