Ana içeriğe geç
Lenovo YOGA 730-15IKB Screen Replacement
Neye ihtiyacın var
  1. Lenovo YOGA 730-15IKB Screen Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Screen Replacement: adım 2, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 2, 2 resimden 2.
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Screen Replacement: adım 3, 1 resimden 1.
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Screen Replacement, Battery: adım 4, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement, Battery: adım 4, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement, Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Screen Replacement: adım 5, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 5, 2 resimden 2.
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Screen Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Screen Replacement, Left Fan: adım 7, 1 resimden 1.
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  8. Lenovo YOGA 730-15IKB Screen Replacement: adım 8, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 8, 2 resimden 2.
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  9. Lenovo YOGA 730-15IKB Screen Replacement: adım 9, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 9, 2 resimden 2.
    • Remove two 4mm Phillips #1 screws.
  10. Lenovo YOGA 730-15IKB Screen Replacement: adım 10, 1 resimden 1.
    • Pull the fan up and towards the front of the laptop.
  11. Lenovo YOGA 730-15IKB Screen Replacement, Right Fan: adım 11, 1 resimden 1.
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
  12. Lenovo YOGA 730-15IKB Screen Replacement: adım 12, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 12, 2 resimden 2.
  13. Lenovo YOGA 730-15IKB Screen Replacement: adım 13, 1 resimden 1.
  14. Lenovo YOGA 730-15IKB Screen Replacement, Motherboard: adım 14, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement, Motherboard: adım 14, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement, Motherboard: adım 14, 3 resimden 3.
    • Remove the fingerprint reader ribbon cable located at the bottom left of the motherboard.
    • Pull up on the black tab on the connector.
    • The ribbon cable should easily pull out of the connector.
  15. Lenovo YOGA 730-15IKB Screen Replacement: adım 15, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 15, 2 resimden 2.
    • Remove the three other ribbon cables at the lower edge of the motherboard.
    • For each, lift up the black tab on the connector.
    • The ribbon cables should easily pull out of the connectors.
  16. Lenovo YOGA 730-15IKB Screen Replacement: adım 16, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 16, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement: adım 16, 3 resimden 3.
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
  17. Lenovo YOGA 730-15IKB Screen Replacement: adım 17, 1 resimden 1.
    • Remove the sticky tape from the top of the wireless card.
  18. Lenovo YOGA 730-15IKB Screen Replacement: adım 18, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 18, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement: adım 18, 3 resimden 3.
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  19. Lenovo YOGA 730-15IKB Screen Replacement: adım 19, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 19, 2 resimden 2.
    • Pull up on the thick gray display cable near the back of the laptop to disconnect the display.
  20. Lenovo YOGA 730-15IKB Screen Replacement: adım 20, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 20, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement: adım 20, 3 resimden 3.
    • The charger port is connected to the computer by a cable at the top left of the motherboard.
    • Disconnect the cable by pulling the bundle of wires firmly toward the back of the laptop.
    • The cable requires some force to remove. Make sure you do not damage the connector or cable.
  21. Lenovo YOGA 730-15IKB Screen Replacement: adım 21, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 21, 2 resimden 2.
    • Remove four 4mm Phillips #1 screws.
  22. Lenovo YOGA 730-15IKB Screen Replacement: adım 22, 1 resimden 1.
    • Pull the motherboard up out of the laptop chassis.
    • If you are replacing the motherboard, make sure to remove the SSD, wireless card, heat sink, and extra RAM. Transfer these components to the new motherboard.
  23. Lenovo YOGA 730-15IKB Screen Replacement, Screen: adım 23, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement, Screen: adım 23, 2 resimden 2.
    • Remove four 4mm (silver colored) Phillips #1 screws.
    • For reassembly, pay close attention to where you reattach these screws. The holes closest to the corner need to be left free. They will be used when you reattach the back cover.
  24. Lenovo YOGA 730-15IKB Screen Replacement: adım 24, 3 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 24, 3 resimden 2. Lenovo YOGA 730-15IKB Screen Replacement: adım 24, 3 resimden 3.
    • Pull the thick gray display cable out from under the hook that holds it in place.
    • Remove the white antenna wire from underneath the hooks near the back of the laptop.
  25. Lenovo YOGA 730-15IKB Screen Replacement: adım 25, 2 resimden 1. Lenovo YOGA 730-15IKB Screen Replacement: adım 25, 2 resimden 2.
    • Tilt the keyboard up to make a 90 degree angle with the screen. This makes it easier to move the display and antenna cables.
    • On the back of the keyboard, slide the white antenna cable past the edge of the hinge.
    • Pull the keyboard upward and towards the front of the screen to make room for the cable.
  26. Lenovo YOGA 730-15IKB Screen Replacement: adım 26, 1 resimden 1.
    • Pull the thick display cable and the black antenna cable past the hinge.
    • Tilt the left side of the keyboard upward. This helps create some room around the hinge.
  27. Lenovo YOGA 730-15IKB Screen Replacement: adım 27, 1 resimden 1.
    • Pull the keyboard up away from the screen. After the display and antenna wires have been moved, the keyboard should easily come apart from the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ellis Ruckman
2.647 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S1G6
3 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
Isn't this missing "How to disassemble the LCD Panel" ? I'll try to take some decent pictures while I'm putting mine back together. Does anyone know where I can buy some of that special adhesive tape that behind this screen?
Nathan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 144
Her zaman: 10,576
