Giriş
This guide explains to how safely locate and remove the battery from your Lenovo Yoga 2 13". It provides a list of the tools required, as well as the easiest way to remove the battery without causing damage.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
12 farklı kişi bu kılavuzu tamamladı.
