Ana içeriğe geç
Lenovo Yoga 2 13" Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: adım 2, 1 resimden 1.
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: adım 4, 1 resimden 1.
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: adım 6, 1 resimden 1.
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Nichelle
1.550 İtibar
5 adet Kılavuz yazıldı
Ekip
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 31,786
