Ana içeriğe geç
Lenovo Yoga 3 Pro Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 Pro Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Battery Replacement: adım 2, 1 resimden 1.
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Battery Replacement: adım 3, 1 resimden 1.
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Battery Replacement: adım 4, 1 resimden 1.
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Battery Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Battery Replacement: adım 6, 1 resimden 1.
    • Carefully lift and remove the battery.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Federico LopezCasildo Jr
1.340 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G17
4 Üyeler
15 adet Kılavuz yazıldı
8 Yorum
Very good and very easy to understand
barri.smith - Yanıt
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
Raewyn Dowd - Yanıt
does this same process work for a lonovo yoga pro 2?
Abi Alexander - Yanıt
Awesome and simple! Thank you!
Hong K. Nguyen - Yanıt
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Erika Mackintosh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 85
Her zaman: 61,409
