Ana içeriğe geç
Lenovo Yoga 6 13ALC6 Lower Case Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: adım 1, 2 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: adım 1, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: adım 2, 2 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: adım 2, 2 resimden 2.
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: adım 3, 3 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: adım 3, 3 resimden 2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: adım 3, 3 resimden 3.
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 3.
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 5, 3 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 5, 3 resimden 2. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 5, 3 resimden 3.
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 6, 3 resimden 1. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 6, 3 resimden 2. Lenovo Yoga 6 13ALC6 Lower Case Replacement: adım 6, 3 resimden 3.
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Sonuç
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Spencer Day
94.560 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 57
Her zaman: 2,133
