Ana içeriğe geç
Lenovo Yoga 6 13ALC6 SSD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: adım 1, 2 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: adım 1, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: adım 2, 2 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: adım 2, 2 resimden 2.
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: adım 3, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: adım 3, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: adım 3, 3 resimden 3.
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: adım 4, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: adım 4, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: adım 4, 3 resimden 3.
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 5, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 5, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 5, 3 resimden 3.
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 6, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 6, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement: adım 6, 3 resimden 3.
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: adım 7, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: adım 7, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: adım 7, 3 resimden 3.
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: adım 8, 2 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: adım 8, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 2.5 mm screw securing the SSD.
  9. Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: adım 9, 3 resimden 1. Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: adım 9, 3 resimden 2. Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: adım 9, 3 resimden 3.
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  10. Lenovo Yoga 6 13ALC6 SSD Replacement, Reassembly notes: adım 10, 1 resimden 1.
Sonuç
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Bir başkası bu kılavuzu tamamladı.
Spencer Day
96.168 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
1Rehber Yorum
Love how everyone says a 2280 won’t fit but the bracket all it does it converts the 2242 to fit in a 2280 slot lol. 2280 works just fine. Stuck an 8TB in mine.
GTAGriff900's Channel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 137
Her zaman: 5,080
