Ana içeriğe geç
Lenovo Yoga 700-11ISK LCD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 700-11ISK LCD Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK LCD Replacement: adım 2, 1 resimden 1.
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK LCD Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK LCD Replacement: adım 4, 1 resimden 1.
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK LCD Replacement, LCD: adım 5, 3 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement, LCD: adım 5, 3 resimden 2. Lenovo Yoga 700-11ISK LCD Replacement, LCD: adım 5, 3 resimden 3.
    • Disconnect the following cables attaching the LCD to the laptop:
    • Touchscreen cable
    • EDP cable
  6. Lenovo Yoga 700-11ISK LCD Replacement: adım 6, 3 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 6, 3 resimden 2. Lenovo Yoga 700-11ISK LCD Replacement: adım 6, 3 resimden 3.
    • Place the laptop with the LCD facing down so that the hinges face opposite you.
    • Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
    • Do not pull on the blue tab of the cable without lifting up the black tabs on the connectors. The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  7. Lenovo Yoga 700-11ISK LCD Replacement: adım 7, 1 resimden 1.
    • Unplug the black and white wireless LAN cables in the upper left corner by gently pulling upwards.
    • To reinstall a wireless LAN card, note that the black cable goes to the MAIN jack, and the white to the AUX jack.
  8. Lenovo Yoga 700-11ISK LCD Replacement: adım 8, 3 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 8, 3 resimden 2. Lenovo Yoga 700-11ISK LCD Replacement: adım 8, 3 resimden 3.
    • Remove the six 5mm Phillips #1 screws located in the top left and right corners to free the hinges.
    • Fully extend the hinges by prying upwards.
  9. Lenovo Yoga 700-11ISK LCD Replacement: adım 9, 3 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 9, 3 resimden 2. Lenovo Yoga 700-11ISK LCD Replacement: adım 9, 3 resimden 3.
    • Remove the base from the LCD by lifting it upwards.
    • Flip the LCD so that the hinges face you and the screen faces upwards.
    • Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
    • Remove the two 4.4 mm Phillips #1 screws located under the screw pads.
    • Pry the two side hinge covers with a plastic spudger and pull them up and away from the LCD.
  10. Lenovo Yoga 700-11ISK LCD Replacement: adım 10, 2 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 10, 2 resimden 2.
    • Remove the LCD hinge cover by gently prying the pieces with a plastic spudger and lifting the hinge cover up and out.
  11. Lenovo Yoga 700-11ISK LCD Replacement: adım 11, 3 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 11, 3 resimden 2. Lenovo Yoga 700-11ISK LCD Replacement: adım 11, 3 resimden 3.
    • Disconnect the white MIC board connecter located near the center of the LCD bezel by pulling it out to the left.
    • Flip the hinges up and remove the hinge rubbers by pulling the wires out and away from the hinges.
  12. Lenovo Yoga 700-11ISK LCD Replacement: adım 12, 2 resimden 1. Lenovo Yoga 700-11ISK LCD Replacement: adım 12, 2 resimden 2.
    • Remove the LCD by carefully pulling away from the hinges and upwards.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Gabrielle Bullen
372 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G6
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Just what I needed to replace the adhesive tape on my screen. Thanks!
Stephen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 39
Her zaman: 8,769
