Giriş
If you are having troubles with your Lenovo's monitor screen or know that you have broken it, you may need to replace your LCD or screen.
Neye ihtiyacın var
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Use a spudger to unclip clips on the front and near the USB ports on each side
Lift the back panel off
Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
Carefully remove the battery from the laptop.
Disconnect the following cables attaching the LCD to the laptop:
Touchscreen cable
EDP cable
Place the laptop with the LCD facing down so that the hinges face opposite you.
Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
Remove the base from the LCD by lifting it upwards.
Flip the LCD so that the hinges face you and the screen faces upwards.
Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
Remove the two 4.4 mm Phillips #1 screws located under the screw pads.
Pry the two side hinge covers with a plastic spudger and pull them up and away from the LCD.
7 farklı kişi bu kılavuzu tamamladı.
Your list of t7 screwdriver costed me to order a wrong one.
it should be T5 but the ad listed T7!!!!!
it is frustrating.
Remy Williams - Yanıt
Mine had T5 as well.
alan - Yanıt
